DremelJohn
When you’re tackling a restoration project or prepping metal for a fresh coat of paint, the right tool can save you both time and effort. That’s where the Dremel Ultra-Saw and the US400 Paint and Rust Surface Prep Wheel come in. This accessory is designed with a durable non-woven abrasive that makes quick work of tough jobs like stripping away old paint, removing coatings, and cutting through scaled rust or corrosion. With its four-inch diameter, the wheel covers a solid surface area while still giving you control and precision for detailed work.
Instead of spending hours with a wire brush or other hand tools, the US400 offers a faster, cleaner, and more efficient option. Many users have shared that it’s become their go-to solution for surface prep, especially when working with steel that needs repainting. They’ve found it not only saves valuable time but also delivers more consistent results than traditional methods. Beyond paint and rust, it’s also handy for general cleanup, making it a versatile accessory for a wide range of projects.
Whether you’re a DIYer restoring a piece of furniture, a hobbyist working on metal projects, or just someone who wants to get the job done right, the US400 Paint and Rust Surface Prep Wheel is a reliable choice that helps ensure your surfaces are properly prepared for whatever comes next.
 Product Overview
  • Quickly strip paint, coatings, scaled rust and corrosion from metal
  • Non-woven abrasive for heavy duty removal of paint and rust
  • Large four In. diameter wheel
  • No need for excessive pressure, the tool does the work
What are your toughest paint and rust removal projects? Share your thoughts below!
