Can't remove bit from Dremel 3000
Wood_carver
New Contributor
I have a Dremel 3000 and cannot remove a bit from the tool.  The tool has an EZ Twist™ nose cap for tighting and loosening the collet that holds the bit.  After using the Dremel today, when I tried to loosen the collet, it would not move.  It appears that the shaft lock button is not holding holding the collet so that it can be unscrewed.
Is there a way to fix this without sending the tool to a repair service?
11 REPLIES 11
Dremel-Peggy
Hi Wood_carver,
Thank you for your question.
After reading your post I would agree with you that it sounds like the shaft lock button needs to be repaired.
Our team will reach out to you through email to confirm the issue and collect more information.
We will certainly help you get back to carving!
Peggy
Anyway you could help? When i hold the lock button on my dremel 3000 it just keeps turning when i try to loosen the tip and I don't want to break anything trying to pry this thing open to locate and fix the problem... Any suggestions?
Good morning,
We are sorry to hear you are having issues with your Dremel 3000 Rotary tool.
How long have you had this tool and are you located in the states?
To help you further I will send you an email with different options.
Hi Peggy. I am having the same problem with 2 of my Dremel 3000s. When I try to loosen the nose cap for the collet, the shaft lock button does not hold the shaft still. I tried holdin the bit still with vice grips, but it doesn't help. How can I repair/replace the shaft lock button? Thanks.
Hi Bourgery,
I apologize for not asnwering your post on the tool issue.  If the collet lock button does not hold the shaft of the tool still, then most likely the shaft lock button is broken.  Parts can be purchased through this link:  https://www.boschtoolservice.com/us/en/dremel/spareparts/search
If we can help you further, please contact our service team directly.
https://www.dremel.com/us/en/service-and-support
jhorstke
New Contributor III
Hi Wood_carver, I have had this happen to me with my Dremel 4000.  The shaft lock button wouldn't hold so I could loosen the collet.  I was able to loosen the bit in the collet by first lightly tapping the tip of the bit with a ball peen hammer and then using a vise-grip pliers to hold onto the bit in the collet so the bit couldn't move, I was able to loosen the collet enough to get the bit out.  I wish you success with this method.  After I had the bit out of the collet, the shaft lock button worked perfectly.  Go Figure?
How did you keep the shaft from turning?
jhorstke
New Contributor III
I kept the shaft from turning by using a vice grip pliers that tightly pinched the bit that was in the collet.
Dremel-Peggy
Hi Wood_carver,
There are two issues that can be happening with the tool.
1. The bit and collet are stuck in the tool.  To help you, see this YouTube video:  https://www.youtube.com/watch?v=ciEGJ0WwzCM
2.  The shaft lock button is broken and it will not hold the shaft in place to be able to remove the collet nut.  In this case, the collect button needs repair.  Our team has reached out to you to help you with this issue.
Let me know if this information helped you.
Peggy
DREMEL-VICTORIA
New Contributor III
Good morning Wood_carver
We are sorry to hear you are having issues wiht the shaft lock button on your Dremel 3000 Rotary tool. How long have you had this tool and are you located in the states if so please give me your email address so I can send you an email in a different forum so we can see how we can help you to get your tool back to working properly.
Once you get back to me I will be able to assist you further.
DREMEL-VICTORIA
New Contributor III
I apologize I responded to incorrect person.
