DremelJohn
The Dremel 8150 8V brushless rotary tool is the brand’s most powerful and precise cordless rotary tool yet, all in a compact design fit for everyday tasks. Combining power, precision, and portability while saving space, it's the ideal tool for both creative and functional home improvement projects. Built to handle a wide range of tasks, from engraving and cutting to sanding and sharpening, the cordless Dremel 8150 is the go-to for tackling tasks with ease.
Key Features of the 8150:
  • Powerful Brushless Motor: Delivers the performance you need for everyday tasks—combining power, precision, and portability in one efficient design.
  • Dimmable LED Light: EZ-Twist LED nose cap offers project illumination and attachment compatibility.
  • Battery Charge Indicator: Keeps you informed of battery charge levels.
  • High Performance Battery: The 8V, 2.0Ah high performance battery is equipped with enhanced technology to provide exceptional power and runtime.
  • Variable Speed Dial: Speed ranges from 5,000 – 30,000 RPM for maximum control and precision.
  • Comfortable Soft Grip: Enhances comfort and control in pencil and barrel grip positions.
Kit Contents:
  • The Dremel 8150 brushless rotary tool kit includes:
  • 8150 rotary tool
  • USB-C charging cord
  • 20 Accessories
    • 191 carving bit (2)
    • 194 carving bit (2)
    • 426 reinforced cut-off wheel (2)
    • 407– ½-inch 60 grit sanding band & mandrel
    • 408 – ½-inch 60 grit sanding band (5)
    • 432–½-inch 120 grit sanding band (5)
    • 932 aluminum oxide grinding stone
    • Collet wrench
    • 402 – mandrel with screw
  • Instruction manual
  • Small, clear accessory storage case
Tool Specifications:
  • Battery: 8.0V Max 2Ah Li-Ion
  • Speed: 5,000 – 30,000 RPM
  • Collet capacity: 1/32” – 1/8”
  • Weight: 14.1 oz / 0.4 kg
  • Tool warranty: 2 years
Key Projects:
  • General applications: Cut, Sand, Engrave, Carve, Grind, Sharpen, Clean, Polish, and Drill
  • Materials: Metal, wood, laminates, plastics, glass, hardware, bolts, acrylic
  • Home improvement and repair such as:
    Support remodels by cutting through various materials like drywall, plasterboard and laminate flooring.
    Clean garage door tracks, grind out rust from outdoor fixtures or remove old grout.
  • Woodworking details and finishes such as:
    Carve details in wood furniture and trim or sand uneven surfaces.
  • Hobby/Craft such as:
    Engrave personal touches to everyday items like terracotta planters, drinking glasses or metal mailboxes.
Frequently Asked Questions:
What type of battery does the Dremel 8150 use?
The Dremel 8150 features a 8V rechargeable USB-C battery, providing enhanced portability and reliable power for uninterrupted use. Using a 2A charger, the user can charge their battery in 165 min, so you’ll always be ready to tackle your next project.
Is the Dremel 8150 compatible with other Dremel accessories?
Yes, the Dremel 8150 is fully compatible with all existing Dremel rotary accessories, ensuring seamless integration and versatility across different projects.
Is the Dremel 8150 compatible with Dremel attachments?
Yes, the Dremel 8150 is fully compatible with most existing Dremel rotary attachments, ensuring full versatility in applications except for routing.
What kind of tasks can the Dremel 8150 handle?
The Dremel 8150 is designed for a wide range of applications, but best suited for engraving, cutting, polishing, sanding, sharpening, and more . It’s equipped to handle everything from delicate, intricate work to medium-duty tasks. The Dremel 8150 is not suitable for grout removal and routing applications.
How portable is the Dremel 8150?
The Dremel 8150 is exceptionally portable thanks to its compact design and lightweight build. It’s small enough to store in tight spaces like drawers or toolboxes and features a cordless rechargeable battery to support mobility.
Who is the Dremel 8150 ideal for?
The Dremel 8150 is perfect for home improvement enthusiasts, DIY hobbyists, and advanced crafters. Its intuitive design and performance capabilities make it a versatile tool for individuals at every skill level.
What materials can I use the Dremel 8150 on?
The Dremel 8150 can be used on a variety of materials, including wood, plastic, glass, metal, and more. Its adjustable speed settings allow it to adapt to diverse project requirements with precision.
Does 8150 have motor brake? And electronic feedback?
Yes, once the tool is turned off it will shut down the rotations under 3 seconds.
Yes, the tool also has electronic feedback. It will adapt to the power needed depending on the application.
Watch
Unboxing Video
Quick Start Guide
Where Can I Buy the 8150?
The Dremel 8150 is available online at all major US retailers and on Dremel.com for an MSRP of $79.99 USD.
HOME DEPOT
AMAZON
DREMEL
