When you see the word MAX on Dremel accessory packaging, you know you’re getting Dremel accessories that are the highest performing and most innovative rotary accessories available. They deliver proven performance that is longer lasting, stronger performing, and highly versatile.
New to the Dremel MAX accessory line are the Max Power Carving bits that are designed to carve out material faster and with maximum efficiency. They can both aggressively remove material and smooth the workpiece to a finish ready for final sanding and make wood carving feel effortless when cutting both with the grain and across the grain. Max Power Carving bits have hardened stainless steel teeth that allow for aggressive carving and high material removal rates in wood, plastic, foam, and rubber while providing resistance to rust and corrosion.
9951 Max Power Carving Bit
The Dremel 9951 Max Power Carving Bit has an 11/32" diameter ball shaped bit that is engineered to rapidly remove material 2X faster than the Dremel model 114 carving bit. The 'ball' profile allows for undercuts and aggressive shaping of concave surfaces.
9952 Max Power Carving Bit
The Dremel 9952 Max Power Carving Bit has a 1/4" small taper shaped bit that is engineered to rapidly remove material 2X faster than the Dremel model 9910 tungsten carbide carving bit. The 'small taper' profile offers accessibility into small, hard-to-reach areas and carving deep holes.
9953 Max Power Carving Bit
The Dremel 9953 Max Power Carving Bit has a 3/8" flame-shaped bit that is engineered to rapidly remove material 2X faster than the Dremel model 124 carving bit. The 'flame' profile is perfect for concave and V-cuts, grooving, and detailed profile carving.
9954 Max Power Carving Bit
The Dremel 9954 Max Power Carving Bit has a 5/16" ball nose shaped bit that is engineered to rapidly remove material 2X faster than the Dremel model 117 carving bit. The 'ball nose' profile allows for round detailed shapes, carving large flat surfaces and creating undercuts with no difficulty.
Dremel EZ411HP EZ Lock Sanding Disc
The MAX EZ411HP Sanding Disc is engineered to last 20X longer than the Dremel EZ411SA Sanding Disc. The EZ411HP features three 1-1/2" (38.1 mm) 60 grit sanding discs. Great for flat sanding and edge sanding of small objects as well as rough shaping, smoothing, paint removal, and rust removal from metal. The accessories are compatible with the patented EZ Lock system making accessory changes quick and easy. For use with the EZ402 EZ Lock mandrel.
Want to see more information these bits?
Visit Dremel.com here!
-John
