DremelJohn
Hi Dremel Community Family,
I'd like to tell you about another option that the Dremel brand has introduced for homeowners and DIY enthusiasts seeking a high-quality oscillating blade that fits their tool. You will now find the search much simpler now thanks to the new line of Dremel Universal True Fit oscillating tool accessories available at Lowe’s.
As the maker behind the popular Multi-MaxTM oscillating tool, Dremel Universal True Fit oscillating blades are focused on solving the pain points that shoppers of oscillating blades often endure. Finding a proper blade fit is a challenge for new and existing DIY oscillating tool users because each different tool interface system calls out a need for a universal solution. Dremel Universal True Fit accessories allow use with all of the current major oscillating tool brands on the market.
Known as a brand built on versatility, Dremel currently offers a wide variety of oscillating accessories, including cutting, scraping and grout removal blades, as well as sanding pads. Other conveniences for shoppers entail additional benefits such as revamped packaging that clearly outlines the materials suitable for each blade, compatible brands, and relative durability based on the construction of the blade.
"We're committed to enhancing our customers' experiences and thrilled to streamline the oscillating blade selection process through the launch of Universal True Fit accessories," explains Ryan Walker, Product Manager for DIY Tools. "By providing top-notch accessories with universal compatibility and ensuring a superior shopping journey, users can devote less time to searching for the perfect accessory and more time to repairing, remodeling, and restoring."
Universal True Fit accessories are offered under four main use categories,  each designed for specific materials or applications:
  • Universal True Fit Wood features both high carbon steel and bi-metal blades designed to cut wood. Ideal for flush cuts and plunge cuts in floors, walls, baseboards, cabinets, and a variety of other applications.
  • Universal True Fit Specialty features accessories for sanding, scraping, and grout removal. Made for specialty applications that require material removal with precision.
  • Universal True Fit General-Purpose features bi-metal blades designed for wood, PVC, and general-purpose cutting. Designed to last 3X longer than Dremel high carbon steel blades. Ideal for flush cuts and plunge cuts in floors, walls, baseboards, cabinets, and a variety of other applications.
  • Universal True Fit Tough Materials features carbide blades designed for cutting tough materials like pipe, metal, and cement board. Designed to last 30X longer than Dremel high carbon steel blades. Ideal for cutting in galvanized and copper pipe, wood trim with nails, plaster, cement board, and a variety of other materials.
Universal True Fit accessories are sold in individual packages and sets and are available at in-store at Lowe’s home centers and Lowe’s online starting August 2024.
See more about Universal True Fit accessories on this page on Dremel.com.
Individual and Kit Universal True Fit Accessories
MM100W-1 Flush cut blade for wood. High carbon steel. Single pack. $12.99.
MM105W-1 Wide flush cut blade for wood. High carbon steel. Single pack. $14.99.
MM200W-1 General purpose flush cut blade for wood and metal. BiMetal blade material. Single pack.
$14.99.
MM200W-4 General purpose flush cut blade for wood and metal. BiMetal blade material. Four pack. $38.99.
MM205W-1 Wide general purpose flush cut blade for wood and metal. BiMetal blade material. Single pack.
$16.99.
MM220W-1 Flooring flush cut blade for wood and metal. BiMetal blade material. Single pack. $14.99.
MM300W-1 Carbide flush cut blade for tough materials (cement board, ferrous metals). Carbide material.
Single pack. $17.99.
MM300W-3 Carbide flush cut blade for tough materials (cement board, ferrous metals). Carbide material.
Three pack. $35.99.
MM505W-1 Carbide blade for grout removal. Carbide material. Single pack. $24.99.
MM620W-2 Rigid/Flexible scraping blade. Two pack. $14.99.
MM700-6 Detail sandpaper for wood (60 grit, 120 grit, 240 grit). Six pack. $7.49
MM714W Detail sanding pad backer. Single pack. $13.99
MM900W-3 Wood cutting variety pack. High carbon steel. Three pack. $21.99.
MM910W-4 Variety kit. BiMetal and High carbon steel. Four pack. $31.99.
MM920W-5 DIY starter kit for general purpose cutting and scraping. BiMetal and High carbon steel. Five
pack. $39.99.
MM960W-8 Value Pro variety kit general purpose cutting of wood, PCV and drywall. BiMetal and High
carbon steel. Eight pack. $39.99
Thanks for letting me share this information with you!
-John
