DremelJohn
Key Features of the Project Multi-Tool:
  • Exclusive Application Selector: Intuitive speed settings tailored to your specific project. Just select your project and go!
  • 4 jobs, 1 tool: A tool that does it all; cuts, sands, scrapes, and grout removal.
  • Easy Accessory Change: Tool-less blade change system that allows you to change accessories by simply twisting the knob, pushing it down, and inserting the accessory.
  • LED Backlit Display: Easily find and select options, even in low-light conditions.
  • Front LED Light: The Multi-Tool LED Work-light illuminates when the tool is in use and will light up the project area to ensure better visibility and accuracy. This makes it the perfect addition for working in dark spaces and tight quarters.
  • Ergonomic Design: Comfortable to hold, ensuring you can work on projects for hours without strain.
  • Rechargeable 12V Power: Your convenient cordless go-to power source for all Dremel Blueprint power tools.
  • Brushless Motor: With project-ready speed control.
Key Projects:
  • Grout removal and tile replacement
  • Renewing caulk
  • Home remodeling and restoration
  • Home décor and design
Tool Specifications:
  • Battery: 12.0V Max 2Ah Li-Ion
  • Speed: 7,000 – 20,000 OPM
  • Motor: Brushless
  • Tool weight: 1.75 lbs. (0.79 kg) (without battery)
  • Package weight: 3.41 lbs. (1.54 kg)
  • Tool warranty: 2 years
FAQs
What is a project multi-tool and what can it do?
A Project Multi-Tool is also known as an Oscillating Multi-Tool. Oscillating multi-tools are versatile tools that cut, grind, sand and remove grout with interchangeable accessory attachments.
On which materials I can use my Multi Tool on?
Cutting: various woods, vinyl, metals, plastics and drywall
Sanding: woods or painted woods
Grout Removal: grout in cracked or damaged tile
Scraping: glue and adhesives
How does the application selector work?
Once you select your project type (cutting, sanding, grout removal or scraping) press the button at the base of the application selector to choose your specific application. Once that is complete, power on and go!
Which accessories can be used with my tool?
Any Dremel oscillating accessories are compatible with the MM12V-S1 Project Muti-Tool
How long does the battery last?
Battery can last several hours depending on frequency of use and application type. A battery indicator light will let know when your battery is at 75%-100% (3 bars), 40%-75% (2 bars), 15%-40% (1 bar) and less than 15% (1 blinking bar)
Is the battery compatible with other Dremel tools?
The 12V battery is compatible with all Blueprint Tools and 12V rotary tools.
Blueprint Multi-Tool Video
Where Can I Buy the Project Multi-Tool?
The Blueprint Multi-Tool will be available for purchase in the United States on April 15, 2025, and will be sold at Lowes.com, HomeDepot.com, Amazon.com, and Dremel.com for $139.99 MSRP.
LOWES
HOME DEPOT
AMAZON
DREMEL
2 Comments
Woodmen45
New Contributor II
Love them kind of tools you can do about anything with them
DremelJohn
Thank you Woodmen45. We agree. Tools that do more than one thing is a core Dremel characteristic. With Blueprint tools, the idea is to not make many tools that only do one thing, but to make a few tools that help you do many things--especially with the common projects people need to around their home or apartment.
