Wooden Coasters
sclowe01
Contributor
I used the Dremel Blueprint sawing platform to cut the strips of teak and poplar which were later gluedtogether. The dremel clamping device held the wood together while the glue dried. Also used the Dremel clamp to hold the coasters while sanding them, utilizing the Dremel cordless 8240 to sand the edges of the coaster. The coasters were then stained and coated with polyurethane.
6 REPLIES 6
DremelJohn
Those coasters turned out great! Nice job using the Blueprint sawing platform for clean cuts, and the clamp setup looks like it helped with the gluing and sanding. The teak and poplar combo looks awesome, and that smooth finish really brings it all together!
sclowe01
Contributor
Thanks! The Blueprint tool made it so easy!
DREMEL-VICTORIA
New Contributor III
I really like the 2 different types of wood you used this looks great. That was a really good idea to use the the teak and poplar woods.
Thank you for sharing these with us.
sclowe01
Contributor
THANK YOU!
Phrogflyer
Contributor II
Nicely done and perfect joints!
sclowe01
Contributor
Thanks!
