DremelJohn
Key features of the all-new Portable Saw Station
  • Effortless Cutting: Make miter, bevel, straight, and rip cuts with ease for all your DIY projects. The Portable Saw Station helps you tackle similar cuts to a traditional miter and circular saw. Cut the most common DIY project materials like trim, vinyl flooring, 1” x 4” and more.
  • Perfect for Small Spaces: Ideal for homeowners, renters, and DIY enthusiasts who need a versatile saw that doesn’t take up much room. The Portable Saw Station easily folds to fit in tight spaces like closets, garages, or under beds.
  • See Cuts Clearly: Visualize your cuts instantly with our integrated alignment laser. This handy feature ensures you get a quality cut every time, minimizing errors, and maximizing efficiency.
  • All-inclusive Support: Comes with cutting guides, material supports, and clamps to make your projects smoother and more manageable.
  • Rechargeable 12V Brushless Power: Your convenient cordless go-to power source for all Dremel Blueprint power tools.
  • DIY Project Partner: Designed to handle all your home decor tasks like feature walls, new trim, custom frames and more.
Key projects
  • Create a board and batten accent wall
  • Put together custom built-in shelving
  • Install baseboard trim and molding
  • Install wood, vinyl, and laminate flooring
Tool Specifications
Portable Saw Station Cutting Depth 90°: ¾" (19.05mm)
Saw Only Cutting Depth: 1" (25.4mm)
Motor: Brushless
Battery: 12V 2Ah Li-Ion
Weight: 16.45 lbs. (7.46 Kg)
Dimensions: 17.44in. x 16.73in. x 7.48in. (44.29cm x 42.49cm x 18.99cm)
 Let's Take a Walk Around the Portable Saw Station
FAQs
What types of cuts can I make using the Portable Saw Station?
Straight cut, bevel cut, rip cut, angle cut. You can select angles on the tool and on the saw station guide.
Is the Portable Saw Station compatible with other tools?
The Portable Saw Station is designed specifically to work with the Dremel 12V Compact Saw. For safety reasons it is not recommended to be used with any other tools.
How do I make angled cuts when visibility is obscured by dust or the miter guide?
To make angled cuts, first ensure the miter guide is set to the desired angle. If dust obscures visibility, use dust management features or pause to clear the area. Trust the miter guide's angle settings and use the laser for alignment.
How do I align the saw with the guide rails and ensure it's properly placed for cutting?
To align the saw with the guide rails, follow these steps: 1. Place the saw at the beginning of the rails. 2. Align the saw's base plate with the rails, ensuring it's flat and secure. 3. Slide the saw into the rails (on right side - inside the rail, on left - on top of the rail). 4. Before cutting, double-check the alignment with your marked line and the laser guide.
What is the cutting depth for the Portable Saw Station?
The maximal depth of cut with straight (0-degree) angle is 23.5mm and the least at 45-degree angle is 14,0mm.
Where Can I Buy the Portable Saw Station?
The Blueprint Portable Saw Station will be available for purchase in the United States on January 7, 2025, and will be sold at Lowes.com, HomeDepot.com, Amazon.com, Menards.com, Walmart.com, Dremel.com and select Walmart stores for $149.99 MSRP.
Lowes
Home Depot
Amazon
We'll update this space a with links to other retailers as they become available!
7 Comments
trollicouture
New Contributor
Looks great, small and practical. I would love to test this.
DremelJohn
Hi trollicouture, We'll see what we can do to put some Blueprint tools into the hands of community members. For right now however, our retailers are taking all available tools so it will still be some time before we do. Thanks for your patience!
Discosaurus
New Contributor
Do you have a release date for this in Australia?
DremelJohn
Hi Discosaurus, Unfortunately we do not. Release dates outside of North America are TBD (To be determinied) at this point in time. Thank you for your interest in the Dremel Portable Saw Station. It is proving to be quite popular in the United States.
VTOOLS
New Contributor
Very interesting product. keep up innovating products !
StefaDema
New Contributor
This portable saw table is in a foldable case! This is a DIY dream. I would love to put my name down to test one of these units.  It looks incredible!
Woodmen45
New Contributor
What I love about that portable saw is you can take it anywhere you want to go and very easy setup and also it all fits in one place also it's very easy to store away
