Dremel Idealab 3D20 Printer Nozzle Only Heats Up Manually
hotm6654
New Contributor
I have a Dremel Idealab 3D20 Printer that has a printer nozzle / printer head that will not stay heated up.  If I go to the menu item thru the LCD and manually heat it up thru the menus, it heats up to 220C.  The problem is that it will not stay hot once I start a build / print.  SO nothing prints.
Has the thermistor failed?  Or is this some other problem?  Can I just replace the printer head?  I did some very large / long prints (8+ hours) about 1 month ago so it seems like this just failed.
1 REPLY 1
Dremel-Peggy
Hi hotm6654,
Thank you for your 3D question.  Our team would be happy to help you, but more information is needed to serve you best.
Please contact the Dremel 3D customer service team to get answers to your question. The phone number is 844-437-6533 and you can reach them between 8am and 5pm Central time. If you prefer using email, send your questions to: https://www.dremel.com/us/en/service-and-support/contact-us
