Versa tip 1550 T2 quit
Hafcanadian
New Contributor
I wanted to repair a plastic device using the flat blade tip (wood burning tip?) on one of my old VersaTip 1550 T2 tools.  I got half way through melting the plastic, and set the tool aside while I adjusted components on the device.  When I picked up the tool again it had quit heating, and I can't get it to heat anymore.  I had to finish the job using a second 1550 T2 I'd bought years ago but had never opened the package.
The core doesn't seem to want to unscrew from the handle so I can try to ferret out the problem.  How does this unit disassemble?  Is there a fuse?
1 REPLY 1
Dremel-Peggy
Hi Hafcanadian,
Thanks for your question.
As for the 1550, the core of the burner does not unscrew.  If the tip is stuck in the tool, we do not have a solution and the tool does not have a fuse.
1550 Corded VersaTip was manufacture from 1990 - 2021.
I wish I had better news for you.  Here is a link to the New Butane VersaTip
https://www.dremel.com/us/en/p/2000-01-f0132000aa
