Dremel 3000 carving
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Email to a Friend
- Report Inappropriate Content
06-21-2024 8:30
First attempt at free hand carving, using Max life burrs, any input on making lines more fluid?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Email to a Friend
06-21-2024 10:01
It's beautiful and the only way to smooth things out even more is through practice. Keep creating!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Email to a Friend
06-21-2024 11:15
Hi Jman2603, what bit did you use for this (number)? Then we can suggest something smoother.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Email to a Friend
06-21-2024 11:20
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Email to a Friend
06-21-2024 11:21
I'm not sure the size but it was this max life bit.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Email to a Friend
06-21-2024 11:39
Hmm, I can usually tell, but this shape is similar to many. https://www.dremel.com/binaries/content/assets/dremel/us/other/rotary-accessory-guide.pdf
The link goes to the Dremel accessory poster. I suggest you try 1-3 more bits that are not your bit and see if they give you the results you are looking for. This result may have something to do with the material you are carving. Is it solid wood or a laminate? Laminates, when carved often look like what you are showing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Email to a Friend
06-21-2024 11:44
Yes it is a piece of laminated mdf. I will try the other bits you have suggested though, greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Email to a Friend
09-29-2024 11:14
It is beautiful! Sometimes looking too close at a piece of freehand work makes it look less refined. Step back and it looks perfect!
