9901HD Tungsten Carving Bit
WhiteG
New Contributor
Purchased this bit cut a fairly intricate pattern with minimal straight lines from 1/8" aluminum sheet BUT have read that it is not acceptable as a "saw-like" tool, e.g., jigsaw.
Is there a Dremel bit(s) suitable for this purpose?  Part numbers would be appreciated.
2 REPLIES 2
Dremel-Peggy
Thank you, for joining our Dremel Community.
The 9901HD Tungsten Carving Bit is for a Dremel Rotary Tool.  Do you own a rotary tool?
To cut 1/8" aluminum sheet material, you can use a rotary tool with a Metal Cut-Off Wheel model EZ456.  But the cut-off wheels will mainly cut straight lines.
Currently, we do not offer jigsaw blades or a metal cutting bit to make curve lines in aluminum.
Let me know if you have another question.
SamihAbdou
New Contributor III
This Dremel bit is for Dremel rotary tools and it is used for applications to shape, smooth, or grind hard materials.  Dremel also provides different cut-off wheels foor different materials suh as wood, plastic,  aluminum and  metals but all will only cut straight lines.
regards,
