Wood Carving with Dremel Rotery
johnbaker
New Contributor II
Hi, anyone out there that has experience carving wood with a Dremel Rotery tool?
Please add:  Wood species, Bits used, Technique, etc
3 ACCEPTED SOLUTIONS
jhorstke
New Contributor III
Hi johnbaker, I have done a number of carvings with my Dremel Rotary tools.  I work between my favorite 4300 with a flex shaft, my 8360 and Stylo.  I have found that for roughing out a shape that an aggressive spoked burr works best, I follow up with both Dremel bits, and carbide bits I have purchased on line.  For detail I use my Stylo with dental drills.  I like working with hardwoods best, as that's where rotary tools really shine, so walnut, maple, mertle wood, cherry.  Anything that's dense. I really don't have any special techniques that I use, it's just carve away until the shape appears.  I think you did a really great job on that table you created!
View solution in original post
johnbaker
New Contributor II
Hi, Thanks for the reply.  Like you I use a 4300 with flex shaft and various burrs to create the carving I am after.  I have found patterns I like and have them enlarged and printed on paper in actual size.  Then I glue the paper to the stock I am going to carve, using the image as my guide.  Once the carving is done I remove the paper.  I have found the Kutzall burrs very helpful as well.
Dremel-Peggy
Hi johnbaker and jhorstke,
Thanks for your comments on woodworking! 😃
7 REPLIES 7
Dremel-Peggy
Thanks for the post johnbaker.  Come on all you woodcarvers, continue the conversation here!
johnbaker
New Contributor II
Dremel-Peggy
Beautiful table, nice work johnbaker.
jhorstke
New Contributor III
johnbaker
New Contributor II
Dremel-Peggy
lanadwodny0921
New Contributor
Thank's to all for the useful info. I'm just getting started on using the Dremel + flexshaft for carving wood.
